I have several small residential jobs where I have sheets A0, A1... through A5 and R1 through R3 (R being for Rendering). On Revit, they show as A0, A1 etc, and in my Project Browers the sheets are shown correct but whenever I print a PDF, the sheets change. A0 changes to D3, A1 changes to D4 and so on.
This has to be a setting on my computer because it is not happening to my co-workers. I do not know what setting may have changed this or if the setting is in Revit for the the Adobe PDF software. It has never been a problem until the last few weeks and I cannot find any threads for in this forum or online for anyone else having this problem...
Any suggestions?
Kristi
Something is wrong with you PDF. If I copy D and paste to Notepad it shows as A. I suggest remove and install the PDF printer, or use another one.
Or, edit the PDF printer and follow the settings below.
Hi @Anonymous
I am checking back to see if there is any progress on this issue? Did the resolution by @ToanDN help?
Let us know if you are looking for more assistance on the community. Please see similar forum thread HERE on other PDF printers.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
