even when I changed the numbers completely they stay in those rows on the cover sheet, any ideas on how to fix this?
Is this a sheet list?
You have to sort the list.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
it is already sorted and there is a A600 series, but those two sheets wont go in numerical order with the rest of the 600 sheets
Steve Stafford
Steve Stafford
@ben_smithZFR74 wrote:
here
Obviously your schedule doesn't sort by Sheet Number.
obviously i just had to change the sequence number in the sheet properties.
No. If you want to sort by Sheet Number then add Sheet Number to the sort list, not Sequence Number.
no, thats why it was out of order the seq no. was listed in the 200's not the 600's in the shet properties now its fixed.
Why do you need Sequence Number when you can simply sort by Sheet Number? Sequence Number is only needed if you DO NOT want to sort by Sheet Number, i.e. A200 -> A600 -> A300.
