Sheet navigation
1 ANTWORT 1
Nachricht 1 von 2
dbroad
162 Aufrufe, 1 Antwort
Sheet navigation
At the end of a job, reviewing and checking sheets should be easier before printing. A sheets set navigation tool or a forward & backward button in the option bar would be helpful if a sheet view is open in a non-tiled mode.  I would expect this tool to be available in the option bar and also have check marks to give the option to close the current sheet view while opening the next.
Currently the best I can do is to collapse the project browser to sheets and cycle through the sheets that way, manually closing and opening each view.  That requires several steps: Adjusting the browser, and closing and opening each view.  Another way is to open a number of sheets at the same time and tab through them.  A page navigation might be more convienient, depending on how much time it takes to open each sheet.
Architect, Registered NC, VA, SC, & GA.
1 ANTWORT 1
Nachricht 2 von 2
dbroad
als Antwort auf: dbroad
Please note that I posted this in the Revit ideas forum and a website error redirected it to this forum.  Wait until this is moved to respond. Thanks.
