Sheet List Linked Model
9 ANTWORTEN 9
Nachricht 1 von 10
1258 Aufrufe, 9 Antworten
There are sheets from the linked model in my sheet list, that I can't find in the original model. In the image below, I can not find sheet 000 in none of the linked models. God knows how much I searched:)) Does anyone have a clue? Thank you!
Tags (1)
Beschriftungen (1)
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
They may not be actual sheet that can be seen in the browser, but place holder sheets added to the link models sheet index.
Nachricht 3 von 10
als Antwort auf: ToanDN
The weird thing is they do not exist in the original model's sheet list or index either.
Nachricht 4 von 10
Check the filters of the original model's sheet list.
Nachricht 5 von 10
There are no filters on that.:erschöpftes_Gesicht:
Nachricht 6 von 10
s.borello
Do you need them?  Probably dummy placeholder sheets... delete them.
Nachricht 7 von 10
TripleM-Dev.net
Hi @Anonymous ,
See if hiding placeholder sheets helps.
Open the sheet schedule and set the filter placeholder sheets to Hide
- Michel
Nachricht 8 von 10
als Antwort auf: TripleM-Dev.net
No, unfortunately it didn't work :enttäuschtes_Gesicht:
Nachricht 9 von 10
syman2000
Did you go to the link model and see if those sheets are there and delete it? If you can't find it, then your other method is to filter out the sheet.
Nachricht 10 von 10
TripleM-Dev.net
Can you share one of the Linked models?
you can delete all modelled content.
