Sheet List Linked Model
9 REPLIES 9
Message 1 of 10
951 Views, 9 Replies
There are sheets from the linked model in my sheet list, that I can't find in the original model. In the image below, I can not find sheet 000 in none of the linked models. God knows how much I searched:)) Does anyone have a clue? Thank you!
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
They may not be actual sheet that can be seen in the browser, but place holder sheets added to the link models sheet index.
Message 3 of 10
in reply to: ToanDN
The weird thing is they do not exist in the original model's sheet list or index either.
Message 4 of 10
Check the filters of the original model's sheet list.
Message 5 of 10
in reply to: ToanDN
There are no filters on that.😩
Message 6 of 10
s.borello
Do you need them?  Probably dummy placeholder sheets... delete them.
Message 7 of 10
TripleM-Dev.net
Hi @Anonymous ,
See if hiding placeholder sheets helps.
Open the sheet schedule and set the filter placeholder sheets to Hide
- Michel
Message 8 of 10
in reply to: TripleM-Dev.net
No, unfortunately it didn't work 😞
Message 9 of 10
syman2000
Did you go to the link model and see if those sheets are there and delete it? If you can't find it, then your other method is to filter out the sheet.
Message 10 of 10
TripleM-Dev.net
Can you share one of the Linked models?
you can delete all modelled content.
Forma Design Contest
Technology Administrators
