I recently tried saving some sheets from Revit to Adobe pdf for printing. I noticed that the text in the pdf sheet was reduced in scale and was not formatted as per the original sheet on Revit. I'm attaching the screenshots of both the Original sheet and the sheet with formatting errors. Any inputs on how to resolve this is appreciated.
Micah
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I used the Adobe pdf print driver that is included with the Adobe Creative Cloud suite. This driver has always worked fine until Revit revision 2017, which I'm regretting having installed. Why am I paying for a Revit subscription when iterations of the software are released with bugs?
Micah
Sorry, I did not mean to say "saved." Rather, I printed as usual from Revit using the Adobe Pdf driver. I have never experienced this issue previously.
Yes Revit 2017 is known for bugs related to text. Although I have not experienced this particular issue I am not surprised it happens to someone else. Anyways, try the below see if it helps:
