Sheet duplication
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
LUCAGUERRA8520
1834 Aufrufe, 9 Antworten
Sheet duplication
Actually, it's not allowed to duplicate sheets while it would be very time saving;
I had an A1 size sheet with 8 drawings inside it, that I need to duplicate and just change the name (of the sheet, only); why it' not possible to skip the actual process, that implies to duplicate each drawing and place them in another sheet? It's a time-consuming procedure without doubt, that I argue, could be easily replaced with a better one.
Luca
Tags (2)
9 ANTWORTEN 9
Nachricht 2 von 10
Ilic.Andrej
als Antwort auf: LUCAGUERRA8520
They made unique views for a reason. Sections show the name of the sheet on which the section is placed. How that mark is going to look like if the section was placed on multiple sheets? But I agree that it would be nice to have the ability to duplicate sheets, its data and all the elements which can be duplicated.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 10
LUCAGUERRA8520
als Antwort auf: Ilic.Andrej
Now you can duplicate sections and the number of the sheet is shown in
each section simbols, one placed over the other. I dont' see any problem
in this. I don't think this is the reason.
thanks
Nachricht 4 von 10
Ilic.Andrej
you can't put one section on two sheets like you would do with legends.
Andrej Ilić
MSc Arch
Nachricht 5 von 10
LUCAGUERRA8520
of course, I know, but in a sheet there is only a section with the same
number or name, so you are wrong again
Nachricht 6 von 10
RobDraw
Setting up all the sheets for a project is time consuming but one sheet by comparison is easy. I've never had a sheet with only the a name difference in the nearly 20 years that I've been setting up large MEP projects. In fact, in my world, we try to avoid duplicating information on different sheets. So, I'm not so sure how much of a demand for this there really is and if it is at all necessary.
I'm sure there is already an "IDEA" for it posted for it over in the ideas forum or over at Augi's wish list. Maybe you can find it and vote it up.
Rob
Nachricht 7 von 10
LUCAGUERRA8520
als Antwort auf: RobDraw
You work in a differente world, in the mep one, where you have much
fewer connections to adiminstrative permission, according to my experience.
If you set a sheet with project drawings, at the end, after construction
and variations, that sheet will become a base for a comparison between
realization and project.
I hope I've been clear
Nachricht 8 von 10
RobDraw
Not at all clear. It's probably a language translation thing.
It sounds like you might be talking about As-Built drawings which are a different set of drawings. Not just a name change.
Rob
Nachricht 9 von 10
jedrzej_pasalski
There are extra plugins for sheet duplication. eg. https://apps.autodesk.com/RVT/en/Detail/Index?id=7824572173744190837&appLang=en&os=Win64
They automatize some processes. There are also apps for views alignments on sheets and duplicating views. All in all the methodology and philosophy is the same however with this apps You can speed up some processes.
Also, for multiple sheets creation remember You can utilize schedule as a 'sheet manager'.
Nachricht 10 von 10
als Antwort auf: jedrzej_pasalski
Why does this need a plugin, Install this with the full revit as we pay a lot of money for half finished software.
