You're way too nice Ms Clark. It is now 2017. Ten years after you posted about the "bug" and we still have no solution for making BOTH shed roof fascia cuts square. and no explanation from Adesk. Does this violate some fundamental law of the universe?
At least some sort of notice should appear when you apply the rafter cut to a roof that it doesn't work for shed roofs.
I find this incredible, 11 years later, we still have this problem. More confusing is that the official example of roof by extrusion uses a spline, and the roof edges seem to be perpendicular to it. Can someone from Autodesk step up to the plate and deliver an official response for Revit 2018?
@jacob wrote:
Still waiting for this to be updated.
How hard is it to make a setting where you select "square cut" and the roof is actually square cut all the way around?
It stinks but using a Opening By Face to cut the edge squarely takes less time then typing this reply.
Yes, that's what we do. And it would take less time to just square cut it using the opening, but when we are having to do it on hundreds of roofs each year, posting a comment to keep the issue alive in an attempt for Autodesk to incorporate this simple request at the good of all Revit users ends up more productive.
Thank you for sharing this workaround to get a square roof edge! Works great. After squaring off the roof edge, the fascia works nicely. It would definitely be better if Revit gave you the option for a square cut edge on a roof - especially since that's how most wood framed roofs are made.
Autodesk!!!! Still no simple square cut edge? Why do you have a two cut -square (that only cuts the lower edge) but not a simple square? Such a basic feature and still missing.
it has been 14 yr and Autodesk has still not fixed this bug, we still cant make squared edge on a shed roof
2 days away from the 15 year anniversary!! Still no fix, but thank you @Anonymous for being the original comment to come up with that work around, thats way better then cut cube we have been using. Ill see you all for the 20 year reunion!
Just doing my part here to keep this alive. 5,638 days. Autodesk, can you do it just to be nice?
