Does anyone know how to fix this issue? When saving a project file this error message appears. After a few tries, it does eventually save the file.
hello. are you on worksharing file maybe someone is opening / working in the central file? thanks
I had the similar problem and found the solution for myself. In my case the error happened on any local file save. It turned out that recently installed anti-virus was blocking revit from validating its license. After turning anti-virus off all started to work fine. So in your case the problem might be similar - some 3rd party app can be the reason of the problem.
If this helped please accept as solution.
I haven't installed anything new recently to have this occur. Will check this out, thank you.
My firm has been encountering this error on a number of projects. It has happened on projects in both Revit 2015, 2017, and 2018. Haven't figured out a solution yet. If you find out anything, please reply.
Are you using Trend Micro antivirus?
Yesterday we had Revit added to the Trend Micro exclusion list and I haven't seen that sharing violation since
