Sharing Violation
Sharing Violation
PrathapSekar
Sharing Violation
PrathapSekar
Hi Masters!!!
          I'm experiencing an annoying think after I format my system. Some days back I had formatted my system, and reinstalled all my software, from that moment I'm facing an error message shown below. Is there any way to get rid of this problem. Please help me to find a solution for this. Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
L.Maas
Maybe you can tell a little bit more about the situation. With this little information it is purely speculating
-When is this error popping up (e.g. during saving, opening projects, starting Revit)
-Which Revit version?
-Latest updates installed (i.e. Revit, windows)?
-Does this happen with all projects?
-Is this relating to central file?
-Where is the central file placed (e.g. local, network)?
-Add ins used?
-Only issues with Revit or also other programs
Some possible causes.
-Slow Network
-Permissions (write) to access folder where project is loacated
-Third party apps/add-ins
-Virus Scanner or Firewall
Louis
Please mention Revit version, especially when uploading Revit files.
PrathapSekar
Thank You @L.Maas!!!
 I have written the answers for your queries.
        During saving the projects and families.
        With all versions of Revit (Arch, MEP)
        Installed UR 3 for 2014 versions, and no UR for 2015, 2016 versions,
        Yes,
      For local as well as central files, But this time I'm asking for local files.
      Always in network,
-Add ins used?
      COINS section box (Downloaded from Autodesk app)
      Also we installed one addin to switch the point-cloud on and off (customized in our Organization and all are installed this, but no one face any problem except me),
     Only with Revit,
**Some possible causes.
-Slow Network
-Permissions (write) to access folder where project is located
-Virus Scanner or Firewall**
     Just want to let you know: If these are the problems to cause the error, why I only need to face this? While all are installed the same addins/third party apps.
     I have not problems with Permissions (write) to access folder where project is located. Kindly get me out from this error. Thanks for your time to taking care on this.
L.Maas
As I understand. You have Revit version 2014, 2015 and 2016 installed on your computer. The issue happens with all three Revit versions, correct?.
You need to do some troubleshooting. I would try to do the following:
- Clean your Temp directory (%Temp%). Try to delete most of the files and folders in there.
- Switch off your virus scanner and fire wall and see if that helps.
- Remove your add-ins
- Create a simple project (not shared) and see If you can save that on your local computer
Between each step you can check if the problem is resolved.
Further upload the journal file just after issue happens. Maybe there is an entry which explains the problem.
(Revit records what happens during session)
The journal files can be found in : %LOCALAPPDATA%\Autodesk\Revit\<product name and release>\Journals
HERE you can find more info about journal files
Louis
PrathapSekar
Thank you @L.Maas
     I have explained the steps I fallowed as you suggested,
           Initially I delete the contents in temp folder (unable to delete some contents), And I start my Revit, after some go it shows the error, (this may because the antivirus ran in background). Again I closed all running files and deleted the file in the temp folder and restarted my system, After that I turned off the antivirus, now my Revit runs fine.
