SHARING VIOLATION ERROR
5 ANTWORTEN 5
Nachricht 1 von 6
vblevin
413 Aufrufe, 5 Antworten
I keep getting this message every time I open a family from a project I'm working on to edit it, and then try to "save-as".
5 ANTWORTEN 5
Nachricht 2 von 6
vitorbortoncello
als Antwort auf: vblevin
The "Sharing Violation" error usually occurs if the file is open in another instance or is locked by another process. Ensure no other Revit sessions or applications are using the file, and try saving it to a different location.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 6
vblevin
als Antwort auf: vitorbortoncello
I'm trying to "save as", not "save", and I tried various locations. Same error message.
Nachricht 4 von 6
vitorbortoncello
Try closing the project where the family is used before performing the "Save As" on the family. If the issue persists, restart Revit
Nachricht 5 von 6
Nachricht 6 von 6
handjonathan
Hi @vblevin
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
