Sharing materials library - Texture Path Issues
I have folders on my PC with textures for each material. I created the materials in Revit and added them to a material library, but when I try to use it on another PC, all the texture files are missing because the paths of the files are referencing where the materials were created.
The tutorials that I found tell me to set up the path in the Revit Options > Rendering, but as I said, I have each material in a different folder, so setting up the path for each one is not a viable option.
I think it should be possible to create a materials library with the texture paths related to the adesklib file, instead of trying to find the images on the C:\Users...
The textures should search the path from where the adesklib file is located, so the file references will not be broken.
