Shared reference point Revit 2023
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mihenderson6YSDE
1377 Aufrufe, 4 Antworten
Hello, I'm a Civil 3D user and very new to revit.  I'm trying to use the "export shared reference points for autodesk revit" to share reference, but I can't figure out how to get the add in that lets me import the xml file.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: mihenderson6YSDE
Nachricht 3 von 5
mihenderson6YSDE
als Antwort auf: ToanDN
Thank you so much, this is going to be a long and painful journey.
I'm trying to follow the Jeff Bartel's workflow and am getting a Differing Coordinate System error "The host model and the link do not share the same coordinate system.  The link's World coordinates will be aligned with this project's shared coordinates."
Is there a workflow to get the revit model on surveyor's coordinates?
Nachricht 4 von 5
You revit model shouldn't have a custom shared coordinates prior to performing the workflow.  Go to Manage > Coordinates > Reset shared coordinates, then follow the workflow.
Nachricht 5 von 5
roethbrad
Is there a download for 2024?
