shared parameters
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
401 Aufrufe, 2 Antworten
shared parameters
Hello. I have applied a shared parameter to a dimension line. Is it possible to delete it from the family?
Thanks a lot
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I want to delete this two
Nachricht 3 von 3
L.Maas
Sure you can delete shared parameters from a family
In the family go to the "Family Types" button.
Then a new window will pop up with all the used parameters inside the family.
You then can look up the parameter, select it and use the delete button to remove it
Of course you loose the possibilty to control the family with that parameter then. It also may affect other parameters in that family, for example when they have a formula referencing to that particular parameter. So properly study what you are doing. And of course make sure you have backups.
Louis
Please mention Revit version, especially when uploading Revit files.
