Shared Parameters
2 ANTWORTEN 2
Nachricht 1 von 3
193 Aufrufe, 2 Antworten
Shared Parameters
I want to create shared parameters that I can use between 3 different PCs in a server that currently are working in a shared model. Do I have to create also a file in the server where I can then store my shared parameters? Any advise? Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You only need one.
Or, I should say the SAME one is used.
Nachricht 3 von 3
cbcarch
If using a LAN w/ Central File and local workstations--yes.
Place the Shared Parameters file on the server and point it to the location at Manage Tab> Shared Parameters.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
