Shared Parameter
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
hliS658H
332 Aufrufe, 2 Antworten
Shared Parameter
In Properties of sheet, there is a Project parameter names as Project status  under "Data", when I click it, it shows -Shared parameters : Project Text.  I added another revision " 90% Design " though Manage/Additional Setting/Sheet Issue/Revisions,  but I don't know how to make "90% Design" show up under "Project Status", so I can choose this as the project status.
2 ANTWORTEN 2
Nachricht 2 von 3
SteveKStafford
als Antwort auf: hliS658H
That's a text field and doesn't have any relationship to the Revisions you create. When you type 90% DESIGN into the filed for one sheet it will be available to select for other sheets.
If you edit your titleblock family to include a Label Current Revision Description you can show whatever you type into that field in the Revision table.
Steve Stafford
Nachricht 3 von 3
The shared parameter has nothing to do with Revisions.  You need to enter the value to the Revision Description yourself.
