I am trying to find out if it is possible to have a single shared parameter report the length of various nested family that are all different lengths.
Pretty much what I am doing is tryin to add the door framing to a door family so that when I load it in to the project the entire framing is visible and can be used as an MTO for the amount of framing material needed. I created the door framing using nested families and that is working fine, the problem is that I am looking for a way to have a shared parameter that reports the varying lengths of all the components so that when it is in a schedule all the lengths are listed beside the corresponding framing component.
I have been trying to figure this out for a while now with no luck so I just want to know if its possible to have one parameter report different lengths within the same family or if I'll just need to include a different length parameter for each component.
