Shared Parameter naming tips
5 ANTWORTEN 5
Nachricht 1 von 6
XXalessio.amodioXX
518 Aufrufe, 5 Antworten
Hi all,
I am trying to menage as best as i can Shared parameters. I would like to have list of shared parameter so named "Company Prefix_Description"
I have noticed that same shared parameter can be used in different categories . E.g.  XX_Height can be used for column height, foudantion height and so on.
So my question is : it s better prepare a bunch of shared parameter for main dimentions and add in different category families, or prepare shered parameter per each category e.g. XX_Height_Column, XX_Height_Beam and so on? Or its better prepare shered parameter so named XX_1,XX_2... XX_n?
Thanks for any tip
5 ANTWORTEN 5
Nachricht 2 von 6
BIMAbhi
als Antwort auf: XXalessio.amodioXX
Here I am adding one link for best practice on Parameter naming convention.
https://www.caddmicrosystems.com/blog/2017/07/revitparameter-namingtips/
Thanks & Regards
BIMAbhi
Nachricht 3 von 6
XXalessio.amodioXX
als Antwort auf: BIMAbhi
Hi
There are some good tips, but quite far for what I am in need. Thanks for the effort
Nachricht 4 von 6
@XXalessio.amodioXX wrote:
Hi all,
So my question is : it s better prepare a bunch of shared parameter for main dimensions and add in different category families, or prepare shered parameter per each category e.g. XX_Height_Column, XX_Height_Beam and so on? Or its better prepare shered parameter so named XX_1,XX_2... XX_n?
Thanks for any tip
Nachricht 5 von 6
My question would be why are you naming Shared parameters (or any parameter for that matter) with Company Extensions? What's the purpose?
May I point out that the OOTB Revit has a "bunch" of in-built Shared Parameters that are the same name across Categories (i.e. Window Family "Width", Door Family "Width", etc.).   Seems to work pretty well.  No conflicts reported.
Nachricht 6 von 6
XXalessio.amodioXX
als Antwort auf: barthbradley
Hi
Main idea is to prepare costum firm family with all shared parameter in order to scheduling easier by presetted schedule in tamplate
