Good morning smart people.
I created a Title block like a parametric family, the same title block can be a project cover sheet, structural plans cover sheet, mechanical plans cover sheet, or just a blank sheet for different disciplines.
I have 3 clients, general contractors, they want their logos into my title block for their projects.
I want to keep my folder clean by having only 1 file for 17 x 22 title block instead of having 3 different ones containing logos for each contractor.
So, I created a shared parameter -image type-, so that I can choose in my project information schedule the image of my client. so, as soon as I load family into my project, image does not show up, it displays name of image file:
any sugestions please?
thank you and stay safe out there
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
"So, I created a shared parameter -image type-, so that I can choose in my project information schedule the image of my client."
I think there is some more to the workflow than just this. Isn't there? How's this parameter control Titleblock logos/visibility?
... I don't think it's possible. But, you could put the Schedule/Image on the Sheet with the Titleblock - minus all the Schedule's text and line work of course.
@barthbradley thank you for your response. I do no get "image" in the sheet schedule
this is what I get when I select the sheet:
And, this is what I get when sheet is not selected:
@barthbradley thank you for your response but you equational explanation is not clear for me, thanks for making jokes of my posts
Try this file see if that is what you want. Unzip them in a folder.
I'm not making jokes. I was being sincere. I did not understand post.
Now, it sounds like you did not understand mine? What I suggested was to put your "Image" Shared Parameter on a Sheet Schedule and then putting the Sheet Schedule on the Sheet. Do you understand?
@barthbradley ok sorry for the misunderstanding. I don't know how to put my "Image" Shared Parameter on a Sheet Schedule and then putting the Sheet Schedule on the Sheet. yes, I understand but I don't know how to make this.
@ToanDN thank you for sharing that. I will try to figure how to use this out
thank you
1. Create Image Type Project Parameter and assign it to Sheets.
2. Create a Sheet List Schedule and add this Parameter from the list of available fields into the Schedule.
3. Go to Appearance Tab and uncheck all the boxes.
4. Drag this Sheet List to a Sheet
5. Find the Image Type Project Parameter name in the Sheet Properties and assign an image to it by clicking on 3 dots in the value field to open the Manage Images dialog box. As soon as you do this, the Image will appear on the Sheet.
Brilliant, THANK YOU. ![]()
@ToanDN Good morning thank you for your idea. I primarily accepted @barthbradley 's answer like a solution but I had to copy and paste the logo everywhere I needed. @barthbradley has came up several helpful ideas to develop my knowledge and thanks to him.
@ToanDN I will accept your response as final solution. it allows me to play with different logos from my clients and create additional labels to play also with my logos.
Thank you both for your commitment, God bless you all
