Hi All,
I ran into an issue using shared parameters.
I have a shared parameter fir weights, I've added this to a bunch of families but forgot one.
After adding the exact same shared parameter to the family, it now schedules as a different field. See the image:
The names are the exact same, I'm pulling both parameters from the same place yet this happens?
Any solutions?
(I know I can combine the parameters to quickly fix it, but I'd rather know why and have a permanent solution.)
If each column represents a unique Parameter Field, how can they be the exact same Parameter from the exact Same Shared Parameter Text File?
@yhalsberghe Can you share your family and shared parameter file so that we can review. That is the only to see what is truly missing or incorrect.
