Shared Parameter Conflict and Family Load Failure in Revit 2025
czZZJZU
czZZJZU
Hi everyone,
I'm encountering an issue while trying to load a custom window family into my project in Revit 2025, and I’d appreciate any help.
Problem Summary
When attempting to load the family Roof-Windows_VELUX_GGL_electric_wall_switch into my project file 039.006_K01_F02_N01.rvt, I receive two main errors:
  1. Could Not Load Family
    I get a message saying:
    “The family 'Roof-Windows_VELUX_GGL_electric_wall_switch' could not be loaded into '039.006_K01_F02_N01.rvt'. Resolve issues in the family and reload if needed.”
  2. Shared Parameter Conflicts
    Revit displays the following error when trying to insert shared parameters (see attached screenshot):
    • A conflict with the existing parameter VentilationArea of type Text vs. the new one of type Area.
    • A second conflict with ThermalTransmittance of type Text vs. new one of type Number.
What I’ve Tried
  • I checked the Family Types dialog in the Family Editor (see third screenshot).
  • The shared parameters are correctly defined in the family as Shared, with matching data types and names.
  • The parameter definitions are consistent with what is needed across other families and schedules.
What I Suspect
It seems that the project already contains parameters with the same names, but with different data types. This is causing a conflict that prevents the family from being loaded.
My Questions
  1. Is there a way to force Revit to overwrite or reconcile conflicting shared parameters during family load?
  2. Would renaming the parameter in the family solve the issue — or would it break tags/schedules relying on it?
  3. Is there a recommended workflow to avoid these shared parameter type conflicts in collaborative environments?
Thanks in advance for any advice or similar experiences.
azad.Nanva
1-No, Revit does not provide a native option to automatically overwrite or reconcile shared parameter conflicts during family load.
2- Yes, it should solve the problem, but it will cause problems with tags, schedule, etc.
3-If you mean parameters with the same name, you can include the parameter type or its dependent element in the parameter name.
VentilationArea_Text
VentilationArea_Area
