Autodesk drive team,
it is not possible to share a folder in drive. Without that is the drive useless for work coorperation. It can be used just as a backup storage.
In shared Revit files in web viewer is appearing only the direct open file. No linked files show in open project. Without that it is almost useless. If I send this link to costumer he can see only the main file, means I can present him only the core building with layouts and 3D. No HVAC installation I can present if they are only linked to main file. And to have HVAC in the same model as building is not a good idea. Also to do any extra exports to presentable format is wasting of time.
Can you do something with that? I can imaging that to show a linked files can be a technical problem but why I cannot share any picked up folder is hard to understand while all cloud systems can do it (as Google drive).
Thank you,
Juraj
Thank you for the tip but it does not sort out the problem I described. I want to see linked files while they are published in Drive and sent as a link to somebody. If eTransmiit creates one revit file with all previously linked revit files than it would be a solution.
Do you have some better tips?
Thank you.
Juraj
