Shared Coordinates
Shared Coordinates
NERDASORUS
Shared Coordinates
NERDASORUS
Hello
i have a modeling file and a documentation file with all documentation created in it.
after the documentation was done, the modeling file has its shared coordinates modified and saved. now, when i open the documentation file, the linked modeling file is rotated and all dimensions is rotated with it.
red is the documentation scope boxes, and green is the modeling file after it has its coordinates modified.
is there a way to revert the modeling file into its correct location in the documentation file?
thanks in advance
Sounds like the Survey Point was accidently moved.  If you know where it was originally, move it back.  If you don't know, open your backup files and see if one has the Link/Survey Point at the correct location.
NERDASORUS
ok i have an open documentation model, if i reload the modeling file, it will move to its new location, and all anotation will be removed, is there a way to reload the file without losing the annotation?
