Hello everyone,
I will be happy to get your help with a strange issue while I'm trying to share coordinate from an architectural to a survey model.
I used the red corner to share the model's coordinates with the new model (based on a survey), and when I'm testing the result with the blue corner - I get a huge difference between the two models \ coordinates.
Please help me!
Thanks a lot
How did you establish shared coordinates? Via acquire / publish coordinates?
what do you mean you are trying to share coordinate from arch to survey? That's done via Acquiring or Publishing Coordinates. But, before you perform an Acquire or Publish , you need to move the Link to a specific location. If you've already done this, then Reset Coordinates, reposition Link to exactly where it should be in the Parent Project and Acquire or Publish again. If the Arch is Linked into the Survey: Publish. If the Survey is Linked into the Arch: Acquire
Question: where's the Model sitting in relationship to the Internal Origin of the Project?
Reset the coordinate and then reacquire the coordinate from the original source file.
One other question. Are you working with multiple sites within the Project? If so, verify the current one in use is the one you want the coordinates to reference.
