Is there a way to create a revolve like shape with the profile shown in the bottom picture with a offset ? or would I have to create a blend and add in void extrusions ?
profile of I want but as a revolve and with a circular offset from top to bottom
Where is the Axis that you want?
Or what is the final shape that you want?
like this
or this
If I'm understanding what you want to do, yes, you can do it as a revolve. Just draw that as the profile, and then draw the path around either the top or the bottom. The bottom portion will be more narrow than the top.
If I do that my revolve go at some twisted angle shown in the photo below
the first picture I want that type of transition with the profile shape all around like a revolve.
You can do it if the profile is a simple shape, by revolving it around a tilted axis, then cut the top and bottom with voids; or by a blend with offset top and bottom profiles. Can't do easily if the profile is like what you show.
Another option is using mass.
right but if I did that with a mass in a project wouldn't I have to create a bunch reference planes all staggered at different elevation to create that shape?
what do you mean by cutting the bottom and top don't you mean the side of the first picture view you showed me ?
See below. But it doesn't work with your profile. What are your trying to model anyway?
@mphungDCHNW wrote:
I'm modelling a transition with a flex in it hense the weird shape
Transition for Flex? Like flex duct? You are over-modeling stuff.
