hi, I am trying edit a slab (roof) using Shape Editing Tools. Adding split line thru middle of a rectangular roof (slab) I can create a slope on one side (top) of the slab but actually because this is a gable part of a L-shaped roof I need raise both sides (top and base) of slab which is giving the same shape using slope arrows in sketch mode but unfortunately sketch is not suitable for this roof because the ridge is as different heights and so i need to specify the join instead of using join/unjoin roof command.
To clarify i added what I need to achieve using the shape editing tools (Screenshot from 2022-03-17 03-11-55) and what I currently am achieving using the shape editing tools (Screenshot from 2022-03-17 03-10-43). after that i will join the roof to the walls using Attach Top/Base if i am doing this wrong then please feel free suggest other way
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von nancywelc.ms071.9.90. Gehe zur Lösung
