Hi
After the last update, shadows are not shown properly.
How can I fix this problem? It just show shadows correctly when I change visual style to realistic.
My graphic card is Geforce 3070 and I have updated it to the last version.
Win 10 pro, 64 gb ram, AMD 3900X
THANK YOU
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You're comparing apples to oranges. Realistic is fundamentally different than Shaded.
...also, see "Realistic" Settings in GDOs.
I run into this issue occasionally. It has to do with graphic card need updating.
thank you for your message
yes, I know they are totally different. My problem is not the quality, it's about accuracy. If you see the shadow in shading style it's sooooo long and not properly right. I just want to know if any setting that I accidentally changed cause this issue.
Open a New Project, go to Plan View and place a Model Family that uses a Masking Region for its Plan View representation. The OOTB Desk Family is one such Family. Now turned on Shadows and toggle the View's Visual Style from Consistent Colors to Realistic. Note that the Family casts no shadows when the Visual Style is Consistent Colors, but does cast shadows when the Visual Style is Realistic. I suspect that is what is going in on your two screenshots above.
It is so weird. I printed and the shadow is ok in print but not on the monitor.
thank you for your help.
