shadow path analysis
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
kevibarr
425 Aufrufe, 4 Antworten
Third year students in my labs have been using revit 2017 for a shadow path analysis. The 12pm shadow is not going north, it is off. It hits due north at 12:34pm, so the software appears to be modelling this incorrect. They have adjusted it to true north but it has made no consequence.
Can anyone help??
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: kevibarr
@kevibarr hello, check screen shot if this is you wanted it to be. thanks
Nachricht 3 von 5
FGPerraudin
Hi Kevibarr,
The sun does not hit true north at 12.
Except if you are one the very lucky location of a meridian... and even so I am not sure that it corresponds exactly to the sun zenith...
It is the whole point of time zones!
I think revit is right, but if you want the sun to hit north at 12 exactly, change the location of the model to one that corresponds!
I could make some research as of the right coordinates, but I am sure that you can fond it on google!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 5
kevibarr
als Antwort auf: ennujozlagam
Thanks ennujozlagam
That is it.
Nachricht 5 von 5
kevibarr
als Antwort auf: FGPerraudin
Cheers FGPerraudin for your your input
