Shading in sections.
4 ANTWORTEN 4
Nachricht 1 von 5
markkibui101
1149 Aufrufe, 4 Antworten
Hi, my concrete elements have been given a shading of -192 192 192-(grey) for cut sections. This works in my drawings except this one view (attached below) where the floor is still darker than the Beam, it s. They have the same material assigned to them. I have tried the Graphics Override in the view but did not work. Help.
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: markkibui101
You have to post more to get an answer. There are so many things that influence how things appear in Revit that this is not enouh to go about. Consider to upload (relevant part of) your project so we can have a look.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
alberto-secondi
If there are no view specific or category overrides I would check the filters.
If it still not working open the beam family and see if the geometry is actually assigned to the material, otherwise it will show as default.
Nachricht 4 von 5
markkibui101
als Antwort auf: L.Maas
Hi, i found the solution. In the Visibility graphics, there is 'Object
Styles',
Nachricht 5 von 5
Styles',
How the heck did Object Styles come into play here?
