Setting up PDF Export Default's in Revit 2023
Samuel_Mangiarelli
Samuel_Mangiarelli
Does anyone know how or where the pdf export defaults are located in Revit and if they can be changed? Every time I start a new project in Revit, I have to add more parameters to the file name when using pdf export, and I'm looking for a way to set it up once instead of the first time I go to create the first pdf in every project.
syman2000
Once you have the setting, I would click on the three dot to save the setting.
Once you done this, you can save it as project template. Choose the template
Your setting will keep intact for new project.
Samuel_Mangiarelli
How do I save the pdf settings as a template file?
syman2000
I would save as Template.
You can also use Transfer project standard and it will save the printer setting
