Setting up drawings for imported families
1 ANTWORT 1
Nachricht 1 von 2
168 Aufrufe, 1 Antwort
Hi All,
I am trying to set up a separate detail sheet in Revit for pergola design.
It is an imported family in a Revit project and I want to set up basic views of the pergola without the site context. (plan, section, elevation).
Looking forward to hearing from all the experts out there.
Cheers!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Imported or Loaded? Is is a loadable Revit Family, or another file type that you are  importing in to the Project?  Regarding views, all stock Project Templates have Plan and Elevation Views.  Sections Views you can create by drawing Section Line through the element after you place it in the Project.  When you get all your Views setup and annotated, place the Views on the Sheet/Titleblock.   It's a fairy straight-forward process.
Is that the information you were seeking?
