Setting the viewcube to planometric (30 deg by 60 deg)
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
2008 Aufrufe, 1 Antwort
Hi I was wondering if there was a way I can set the viewcube a specific angle or planometric which 30 by 60 rather than the usual isometric of 30 by 30?
Thank you
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: Anonymous
@Anonymous
Option 1: Using Revit API you can:
  1. refer to this post
  2. Refer to this post as well
Option 2: Orienting view to Elevation/Section + Eye elevation
  • You can place a Section or Elevation oriented 30 or 60 degrees on any plan view
  • In 3D Isometry window; right click the cube and orient view to that section/elevation
  • on the properties panel Change Eye Elevation as required
Option 3: 3D Mass or Surface
you can Place a 3D Cube/Mass or a surface oriented to the angles you want XYZ then orient the isometry view to the a plane
