Set stairs to end with riser by default in assembled stair
2 ANTWORTEN 2
Nachricht 1 von 3
622 Aufrufe, 2 Antworten
Hi, I am looking for a way to set stairs to end with riser by default in assembled stair, thank for any help
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
The solution provided by @barthbradley in the other thread should answer your question perfectly.
Nachricht 3 von 3
als Antwort auf: ToanDN
@Anonymous: I see you are making the rounds today about this. I just reply back to you on other thread.
If the solution I posted on that thread is not working for you, it is probably because you are improvising on the workflow. Follow the steps precisely in the order I listed them. Remember, this procedure is for creating new default properties that will be applied to all future stairs of that type. It does nothing retroactively.
