Is there a setting to adjust this value the level lines are extending past the cropped view?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Annotation Crop is probably what you want to look for.
About the Crop Region | Revit LT 2018 | Autodesk Knowledge Network.
Thanks for sharing. However, I am talking about the datum extends and by the sounds of it the value they extend past the crop region does not have a parametric input and must be adjusted manually.
No. The default distance is hardcoded and if you manually grip stretch it, it's your business to manually update should the view crop region changed in the future.
