Set custom door shared parameter (swing direction) from mirror direction
1 ANTWORT 1
Nachricht 1 von 2
325 Aufrufe, 1 Antwort
I designed a door and inserted some 300 of it around a building, flipping direction by <space bar>. Now I'd like to set a shared text parameter for swing direction to see in a door schedule. Is there some way I can automate or semi-automate setting the swing direction parameter based on some mirror parameter(?) or similar?
Or at least some way I can manually view the mirror direction in a list, so I can manually edit it without going through the floor plans.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
This is not simple, or even possible, to do within Revit.  Read more about the Dynamo approach.
Dynamo for Revit Door Handing Management?
