I have a model that I want to separate into two models, linked to eachother.
I want one model to be all the wall, door and floor elements.
I want the second model to just be furniture and rooms
Is there an easy way I can move this furniture and rooms into a new linked model?
Gelöst! Gehe zur Lösung
Gelöst von JasonKunkel. Gehe zur Lösung
I cannot think of a built-in function in Revit that will support this. I think, unfortunately, your best bet is going to be to make a copy of the model, link them together, and then start deleting elements.
Making some 3D views with the categories you want to keep turned off in each model will probably speed up selecting what you want to delete.
And make sure your links are set to Room Bounding or those Rooms in the model with no Walls will start breaking.
You can give this a try too....
OPT 1
OPT 2
Howard Munsell
