How can I separate the columns at the levels? Segment the column at each level
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Gelöst von JJWGallagher. Gehe zur Lösung
I would adjust the 'Top Level' of your columns so that they are only one storey high, then copy/paste the columns on the other floors.
I do not think there is a plugin available for this, because it can be done in a short time. It is not much more than selecting and copying (or arraying) the columns to the different levels. A plugin would not add a lot to the process.
Louis
Please mention Revit version, especially when uploading Revit files.
