Hi! I wanted to know if it is possible to tag the window casing profile that i did (via sweep) inside my window family? I know that naturally we can tag the window itself, but I want to tag separately the window casing sweep I did so I can put it into my finishes schedule as a separate "trim" element. Hope someone could help me with this. Thanks!
P.S. The casing is just an in-place sweep within the family and not nested.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If you create the casing as a shared family and nest it inside the window family then you can tag and schedule them separately in the project.
