I want to send via email a Revit file that contains several other Revit linked files.
Which is the best method to do this so that there is no need to relink when opening the file?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Use Transmit a model tool and look at the options to include links and a host of others. It's a very useful tool but you will need to close all models from the session before running the tool.
