Semi wireframe walls/mip
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
D_Slaa
283 Aufrufe, 4 Antworten
In camera views and some 3d view in pretty much all my projects on multiple machines I get a semi-wireframe effect. Where I have thin elements such as wall base extension or trim modelled on the wall I can see through those parts. Views are hidden line, no transparencies in wall materials. Effect goes away when zooming in on an element.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: D_Slaa
Sounds like you are describing a common issue where a super thin layer doesn't hide what's underneath it, but I don't see that in your screenshot.  I see what looks like surface patterns.  Maybe they're not.
Can you hide in view what's underneath?
Nachricht 3 von 5
Nachricht 4 von 5
This is a normal behavior of Revit treating thin layers.  Export to PDF or images with higher resolution will eliminate most, if not all the glitches.
Nachricht 5 von 5
D_Slaa
als Antwort auf: barthbradley
It does look mostly like it yes, but there is no belly band between the 2nd/3rd floors. That is the wall geometry showing where there is a wall base offset to cover the floor where the siding runs past the floor.
