Self-Illuminating Materials
4 ANTWORTEN 4
Nachricht 1 von 5
1180 Aufrufe, 4 Antworten
I created a modeled-in-place component which I assigned to the category "lighting devices".  The material I assigned was a self-illuminating one, and it lights up like a dying star.  However, it does not cast any light on its surroundings.  Why doesn't it, and how can I get it to cast light?  It seems useless to have an option to "self-illuminate" where it literally just glows without lighting effects, and then have a SEPARATE option to actually make a light for real this time.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Want Light? Use a Light Source.  Self-Illumination is not one.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Nachricht 3 von 5
als Antwort auf: barthbradley
I understand that, but how do you make a light source that is not one of the predefined standard shapes?  If I'm using an embedded strip fry-reglet that rounds 90 degree corners as a band, is there a way to do this easily?  I've found that making a family for each and every band is very time consuming (this is just a concept package)
Nachricht 4 von 5
You can create a shared family with a linear light source, nest it in your fry reglet family, copy it to make the L.
Nachricht 5 von 5
You want something like Rope Lighting?
...additionally, you could do rope lighting using an Adaptive Divided Line with a Light Source "Repeater". That make sense?
..You can find quite a few Revit Families of this type by Googling it.
