Is it possible to filter select parts by construction type? I can turn them off and on with a schedule but I want to be able to select only the finish layers to modify them.
You can add the parameter Construction to schedules or use it in Filters but it is a preset reporting parameter (ie: for walls all layers outside the Core Boundaries are finishes regardless of the number of layer)
if you want to narrow the filter to specific layers you will need to create/add a project Parameter to parts....However, that being possible only as an Instance parameter, inputting the values would be a nightmare
Thanks!, I use the construction parameter in schedules to turn parts on and off. I was hoping to use a filter to modify the selection without manually modifying them.
Well then I would suggest that you explore dynamo...however, I do believe you know your way to the dynamobim forum since I have noticed you around a couple of times ![]()
Yea, I need to explore that option. I have not had the time to really dig into Dynamo. I want to but it is a new skill for me.
