Hello, is there an easy way to select points on topography lines when modeling terrain? Or should I choose one by one? I will be glad if you help.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
What do you want to do with them?
Move them all at the same time? Sure; window select a bunch and move or nudge them. If the purpose it to change their Elevations, then do them one by one.
I wanted to change their elevation, as I understand I have to do it one by one. Thank you for your answer.
