After creating a revit family, I would like to set a default Family Type that will be always the one to appear when inserting the family into any project.
For some cases I just need to save the file with this Family Type selected and it will be this Type the one to show when loading into a project, however there are other families that have been created and this workflow don“t work.
Does anyone has any idea what could be a solution for this case? Please see screenshot below for better understanding.
Much appreciated your time and support.
Family Type selected when saving:
Family Type loaded into project:
If you are going to use Family Types, then convert your Parameters from Instance to Type.
Maybe I misunderstood. It sounded like you were saying that when place an instance of a Family Type in the Project, it doesn't always use the "default" Parameter Values -- those values you defined in the Family itself.
Why don't you select a family type from the Project Browser and drag drop it on to a view?
