Select Tags by its host element parameter value
2 ANTWORTEN 2
Nachricht 1 von 3
kite15
341 Aufrufe, 2 Antworten
Can you please help how it can be possible to filter or select all placed tags by its host element parameter value?
Explanation:
Suppose, I have some tags to different wall and needs to select / filter those tags which host elements have a parameter named like width and size = 8".
Do it can be possible by default Revit or we need to create some dynamo.
Please, redirect me if there have any similar kind of dynamo is available.
Thanks..
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
EATREVITPOOPCAD
als Antwort auf: kite15
https://forum.dynamobim.com/t/select-an-element-by-host-parameter/41566
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 3
I'm kind of lost here. So, you want to select all the Tags of a particular Type in the View? What about Select All Instance in View?
FWIW: Tags are View-Specific Elements.
