Select All Instances In Entire Project Not Finding All Instances:
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
2661 Aufrufe, 7 Antworten
We are switching out some Keynote Tags for a new family.
My process is to Select All Instances In Entire Project from the Project Browser; then change the tag.
However, for one family the Select All Instances says there are zero; then tells me it will delete 52 instances when I try to delete it.
Is there a way I can find or select these 52 instances it is referring to?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
They could be placed on Legend views.
Nachricht 3 von 8
Why not just delete the family from the Project Browser, then reload the  Family?
Nachricht 4 von 8
als Antwort auf: barthbradley
Thanks for your replies!
I might have misunderstood your Legend View comment, @ToanDN.
Since the only two available fields in the Keynote Legend are Value and Text, not sure how to find the family tag in there.
@barthbradley, I hesitate to delete the 52 instances (if they really do exist somewhere) because I want to replace "Keynote Text - Arrow Left" with "Left Short" so we don't lose any work.  As I said, the select all comes up with zero and when deleting 52 instances are found...not sure how or why.
Nachricht 5 von 8
Does the Tag appear in Purged Unused?
Nachricht 6 von 8
No, it does not appear in the Purge Unused.
Nachricht 7 von 8
Legend Views:
Nachricht 8 von 8
als Antwort auf: ToanDN
Ah!  I see, @ToanDN.
You are correct!  They are hiding in wall assembly legend views.
Good to know...
Thanks for the help and solution!
Thanks for your time, too, @barthbradley!
