Sefaira Plug In Issue
I download the Sefaira plug in and when I clicked on the plug in in Revit I received the following error "Object doesn't support property or method 'addEventListener'. How do I fix??
L.Maas
This seems to be an issue with the plugin. The code tries to do something that Revit does not have available.
In this case it is best to go back to the source, the creators of the Sefaira add-in. They should be able to tell you what is happening
Louis
Please mention Revit version, especially when uploading Revit files.
jpprovincio94
Hi! Did you ever figure out this issue? I'm having the same problem
