Seeking LED Light Strips
2 ANTWORTEN 2
Nachricht 1 von 3
giffordwhyte13
224 Aufrufe, 2 Antworten
     Does anyone has a LED Light Strip familie they would like to shear, if yes.
     You can email me at: giffordwhyte21@gmail.com.
Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
mhiserZFHXS
als Antwort auf: giffordwhyte13
You already posted this. You won't typically find a ton of success just asking for other people's work here. Have you searched for them yourself? BIMobject.com is usually a decent place to look. Or check manufacturer's websites. Or better yet, you can make them yourself to fit your needs exactly.
Nachricht 3 von 3
HVAC-Novice
Don't double-post for the same issue.
Provide some requirements and what you have done/found so far. We can answer specific questions if you are stuck with something specific. There was a recent thread that might be helpful.
knowing this will be helpful in advising what a good and efficient approach is:
- look at manufacturer spec sheet to see what options there are (length increments available), if there are bends etc.
- determine if you need ies fil function and power (those data change based on strip length)
- you need those often, or only one single time?
Revit version: R2025.4
