seeking help regarding project units
Hello, I've a problem with my Revit 2016 software. i'm getting only
metric units but not imperial even after i change the units in manage tab i'm still getting my wall dimensions as metric units. can you please help with this issue. please and thank you
If you started the project as Metric then all the content already loaded in the project remain Metric.  Changing Project Units alone cannot convert the content, dimension units from Metric to Imperial.
I would suggest you restart it from an Imperial Template instead of trying to fix what you have.
thank you for immediate response. Even i tried that too. but there is imperial template to start. i'm thinking to uninstall the software and re-install once again from auto desk. will it help me ?
No need to un-install. Just do a re-install and add Imperial content within the installation options.
