SEEK in r2019
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
steve
5799 Aufrufe, 5 Antworten
SEEK in r2019
where is "seek" in r2019?  (seek sends you to the download center for families) It used to be found in the insert heading.
Also - where did the link to Add-ins go in r2019.  Used to be at the upper right hand corner next to the search bar.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: steve
SEEK died a few years back.
Link to the archived content: http://revit.autodesk.com/library/archive9/html/
Link to BIM Object: https://bimobject.com/en
Add-in drop menu is still there.  But if you are talking about the app store then click on the shopping cart icon nest to the username upper right corner.
Nachricht 3 von 6
steve
als Antwort auf: ToanDN
Thanks.   Where did the add-ins center go.
Nachricht 4 von 6
Nachricht 5 von 6
Viveka_CD
Hi @steve
If you find posts by @ToanDN have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Nachricht 6 von 6
Autodesk Seek changes to BIMobject add so you must to download and install BIMobject add into Revit 2019 and it will work as Seek.
